[GRASS5] [bug #2855] (grass) r.reclass GUI bug
Maciek Sieczka via RT grass-bugs at intevation.de
Fri Sep 2 12:21:33 EDT 2005
mneteler wrote
> Should be fixed. Please try again.
Well, I will be taken for a pain in you know where, but:
1. r.reclass.rules is only workaround, not a fix (though I know in current GUI
we shouldn't expect anything more)
2. if a novice Grass user issues a command r.reclass from the command line, he
will be still in problem, as the default for interactive use in 6.1 is GUI -
and he won't even know there is r.reclass.rules; especially that manual
doesn't mention that...
Maciek
-------------------------------------------- Managed by Request Tracker
