[GRASS5] Re: auto-locate EPSG
Markus Neteler
neteler at itc.it
Sat Apr 29 13:10:55 EDT 2006
On Sat, Apr 29, 2006 at 06:59:26PM +0200, Markus Neteler wrote:
> > > I tried to add you suggestions bug autoconf gives me bad
> > > news. Apparently I made something wrong.
> > There were some bugs in the macros in my email.
> > > Attached a opatch with your suggestions - may I ask you
> > > to try it (at least autoconf-2.13) and then submit?
> > > Hamish is elected beta tester for Debian :-)
> > I've committed the changes. Everything appears to work insofar as the
> > specified directory gets passed to the projshare.sed script.
> Glynn,
> I have tested it, but it seems to fail:
> checking for location of External PROJ.4 data files...
> checking for /epsg... no
> configure: warning: *** Unable to locate PROJ data files.
> checking for nad2bin... /usr/local/bin/nad2bin
> I have things in /usr/local/... and usually do not use any
> parameters for proj.
> Maybe /usr/local/share needs to be predefined somewhere to catch that?
I guess that
$PROJLIB/../share
should be predefined (will catch most cases).
Markus
> As far as I understand the code
> $with_proj_share
> is not defined in this case - subsequently PROJSHARE is not
> predefined.
> Nice, soon we'll have this long standing problem of hard-coded
> path being removed.
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
