[GRASS5] Build-indep (was [GRASSLIST:10072] debian compilation (r.sim.water))
Francesco Paolo Lovergine frankie at debian.org
Thu Feb 2 05:27:30 EST 2006
On Wed, Feb 01, 2006 at 07:38:43PM -0500, Steve Halasz wrote:
> Note that fakeroot will still be called when building the documentation.
> The makefiles are patched to do this since the documentation doesn't
> seem to get built otherwise. You can remove the patch from
> debian/patches/00list if you want to build entirely without fakeroot.
> Steve
About that, we need to split up the documentation (and arch-indep) building and the
binaries building in rules file. I see that 'htmldocs' target seems creating
only the programming manual by doxygen (which needs to be added too, btw).
Any idea about what target can be used to install all html/man pages
without building the whole beast?
Francesco P. Lovergine
