[GRASS5] d.what.rast strange values outside of map
Markus Neteler neteler at itc.it
Thu Feb 2 08:38:19 EST 2006
I discovered an unhelpful behaviour of the GRASS monitor
or d.what.rast
#generate a hemisphere (use in non-LatLong location, e.g. Spearfish):
testsuite/raster/rhemisphere.sh
#zoom to hemisphere:
g.region hemisphere -p
#generate box of same size:
v.in.region hemisphere_box
# open monitor with different ratio than map:
export GRASS_WIDTH=1000
export GRASS_HEIGHT=500
d.mon x0
# view the map and box
d.rast hemisphere
d.vect hemisphere_box type=boundary
#click into no data pixels at border (outside of map box):
d.what.rast
1267(E) 437(N)
hemisphere in neteler, quant   (1080098213)
hemisphere in neteler, actual  (-3199042392403159334141127237487472760781471376965238957138138332769142568673864556645968880013387064229402063231226593015070762178538729445017824264192.000000)
1293(E) 253(N)
hemisphere in neteler, quant   (1081451460)
hemisphere in neteler, actual  (-0.000000)
Looks fairly ugly.
uname -a
Linux bartok 2.6.9-22.0.1.ELsmp #1 SMP Tue Oct 18 18:39:02 EDT 2005 x86_64 x86_64 x86_64 GNU/Linux
Is this somewhat related to
 http://www.intevation.de/rt/webrt?serial_num=2986&display=History
A fix would be appreciated.
Markus
