[GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window interferes with map window
Request Tracker
grass-bugs at intevation.de
Thu Feb 2 05:53:31 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4052
Subject: gis.m: d.vect.thematic legend window interferes with map window
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060202
With today's CVS head tree freshly compiled, there seems to be a problem of inteference between the map and the legend in d.vect.thematic. Two cases:
- When I uncheck "create graphic legend", then the x0 monitor opens and all the GUI elements freeze until I close this monitor. Then the thematic map is correctly displayed in the map display.
- When I check "create graphic legend", the same happens with the x0 monitor (i.e. the GUI freezes until I close the x0 monitor), but then it is the legend which is displayed in the map display, not the map...
Moritz
-------------------------------------------- Managed by Request Tracker
