[GRASS5] Re: [DebianGIS] Build-indep (was [GRASSLIST:10072] debian compilation (r.sim.water))
Steve Halasz debian at adkgis.org
Thu Feb 2 20:48:17 EST 2006
On Thu, 2006-02-02 at 11:27 +0100, Francesco Paolo Lovergine wrote:
> On Wed, Feb 01, 2006 at 07:38:43PM -0500, Steve Halasz wrote:
> > Note that fakeroot will still be called when building the documentation.
> > The makefiles are patched to do this since the documentation doesn't
> > seem to get built otherwise. You can remove the patch from
> > debian/patches/00list if you want to build entirely without fakeroot.
> > Steve
> About that, we need to split up the documentation (and arch-indep) building and the
> binaries building in rules file. I see that 'htmldocs' target seems creating
> only the programming manual by doxygen (which needs to be added too, btw).
A while back doxygen generated files weren't getting cleaned:
http://grass.itc.it/pipermail/grass5/2004-November/016287.html
This might still be a problem. I never looked into the cleandocs target
that Markus mentioned. Maybe that just needs to be added to
debian/rules' clean target.
Steve
> Any idea about what target can be used to install all html/man pages
> without building the whole beast?
