[GRASS5] [bug #4055] (grass) Skript / module to create new chart vector themes
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 3 08:24:15 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4055
> Subject: Skript / module to create new chart vector themes
> Platform: GNU/Linux/x86 grass obtained from: Other (CDROM etc) grass
> binary for platform: Downloaded precompiled Binaries
> Would be great to have a script/module for creating a chart vector
> theme. This would make it possible to display charts also in QGIS or
> other applications (Mapserver!).
Personally I think that this should always be part of the display and
not part of the themes. In ArcView the existing scripts use the theme
solution and it is a pain in the * to work with as you have to relaunch
it (and create more and more themes) until you get the right size. I
think QGIS should deal with this directly...
Moritz
