[GRASS5] [bug #4055] (grass) Skript / module to create new chart vector themes
Radim Blazek radim.blazek at gmail.com
Fri Feb 3 08:34:26 EST 2006
On 2/3/06, Moritz Lennert <mlennert at club.worldonline.be> wrote:
> > Would be great to have a script/module for creating a chart vector
> > theme. This would make it possible to display charts also in QGIS or
> > other applications (Mapserver!).
> Personally I think that this should always be part of the display and
> not part of the themes. In ArcView the existing scripts use the theme
> solution and it is a pain in the * to work with as you have to relaunch
> it (and create more and more themes) until you get the right size. I
> think QGIS should deal with this directly...
What is the 'theme'?
Radim
