[GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window interferes with map window
Moritz Lennert mlennert at club.worldonline.be
Sat Feb 4 16:33:07 EST 2006
On Fri, February 3, 2006 20:00, Michael Barton wrote:
> At the moment, you just need to turn off the graphic legend option if you
> use it in the new GIS Manager.
This is not what I experience. As you can see in what I wrote below, when
I uncheck (i.e. turn off) the graphic legend option, I still get a
traditional x monitor which opens and which I have to close in order to be
able to see the map.
Moritz
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Michael Barton <michael.barton at asu.edu>
>> Date: Thu, 02 Feb 2006 12:50:55 -0700
>> To: Michael Barton <michael.barton at asu.edu>
>> Conversation: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>> Subject: FW: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>> window
>> __________________________________________
>> phone: 480-965-6213
>> fax: 480-965-7671
>> ------ Forwarded Message
>> From: Request Tracker <grass-bugs at intevation.de>
>> Reply-To: Request Tracker <grass-bugs at intevation.de>
>> Date: Thu,  2 Feb 2006 11:53:31 +0100 (CET)
>> To: <grass5 at grass.itc.it>
>> Subject: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>> window
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4052
>> Subject: gis.m: d.vect.thematic legend window interferes with map window
>> Platform: GNU/Linux/x86
>> grass obtained from: CVS
>> grass binary for platform: Compiled from Sources
>> GRASS Version: cvs_head_20060202
>> With today's CVS head tree freshly compiled, there seems to be a problem
>> of
>> inteference between the map and the legend in d.vect.thematic. Two
>> cases:
>> - When I uncheck "create graphic legend", then the x0 monitor opens and
>> all
>> the GUI elements freeze until I close this monitor. Then the thematic
>> map is
>> correctly displayed in the map display.
>> - When I check "create graphic legend", the same happens with the x0
>> monitor
>> (i.e. the GUI freezes until I close the x0 monitor), but then it is the
>> legend which is displayed in the map display, not the map...
>> Moritz
>> -------------------------------------------- Managed by Request Tracker
>> ------ End of Forwarded Message
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
