[GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window
interferes with map window
Michael Barton
michael.barton at asu.edu
Mon Feb 6 14:31:01 EST 2006
I just uploaded updates to gism2 that fix the issues with thematic mapping.
Essentially, I've created a new legend output window as a TclTk canvas in
the GIS Manager. This has several nice features:
Users can select the font (including size, bolding, italics, etc) and font
color for the legend title, subtitle, and item labels
The display of thematic items is nicer
You can save the legend to a very nice EPS file for use in other programs.
IMPORTANT NOTE: You must install a new version of d.vect.thematic (posted to
the cvs and my website today) for thematic mapping to work in the new GIS
Manager.
I also fixed the raster arrow issue and a couple of minor bugs.
I posted the updates to the cvs and my website.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Moritz Lennert <mlennert at club.worldonline.be>
> Date: Sat, 4 Feb 2006 22:33:07 +0100 (CET)
> To: Michael Barton <michael.barton at asu.edu>
> Cc: 'grass developers list ' <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
> window interferes with map window
> On Fri, February 3, 2006 20:00, Michael Barton wrote:
>> At the moment, you just need to turn off the graphic legend option if you
>> use it in the new GIS Manager.
> This is not what I experience. As you can see in what I wrote below, when
> I uncheck (i.e. turn off) the graphic legend option, I still get a
> traditional x monitor which opens and which I have to close in order to be
> able to see the map.
> Moritz
>> Michael
>> USA
>>> From: Michael Barton <michael.barton at asu.edu>
>>> Date: Thu, 02 Feb 2006 12:50:55 -0700
>>> Conversation: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>>> Subject: FW: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>>> window
>>> __________________________________________
>>> phone: 480-965-6213
>>> fax: 480-965-7671
>>> ------ Forwarded Message
>>> From: Request Tracker <grass-bugs at intevation.de>
>>> Reply-To: Request Tracker <grass-bugs at intevation.de>
>>> Date: Thu, 2 Feb 2006 11:53:31 +0100 (CET)
>>> To: <grass5 at grass.itc.it>
>>> Subject: [GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend
>>> window
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4052
>>> Subject: gis.m: d.vect.thematic legend window interferes with map window
>>> Platform: GNU/Linux/x86
>>> grass obtained from: CVS
>>> grass binary for platform: Compiled from Sources
>>> GRASS Version: cvs_head_20060202
>>> With today's CVS head tree freshly compiled, there seems to be a problem
>>> of
>>> inteference between the map and the legend in d.vect.thematic. Two
>>> cases:
>>> - When I uncheck "create graphic legend", then the x0 monitor opens and
>>> all
>>> the GUI elements freeze until I close this monitor. Then the thematic
>>> map is
>>> correctly displayed in the map display.
>>> - When I check "create graphic legend", the same happens with the x0
>>> monitor
>>> (i.e. the GUI freezes until I close the x0 monitor), but then it is the
>>> legend which is displayed in the map display, not the map...
>>> Moritz
>>> -------------------------------------------- Managed by Request Tracker
>>> ------ End of Forwarded Message
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
