[GRASS5] [bug #4052] (grass) gis.m: d.vect.thematic legend window
interferes with map window
Glynn Clements
glynn at gclements.plus.com
Tue Feb 7 15:48:42 EST 2006
Michael Barton wrote:
> It has to do with the way the display drivers for GRASS work. If I
> understand it correctly, vectors are displayed as raster images.
If you're displaying something on a raster device (e.g. a PC monitor),
whatever you are displaying is going to get converted to a raster
image at some stage. The only issue is where and when the
rasterisation occurs.
