[GRASS5] Re: [bug #4064] (grass) r.in.srtm: doesn't work, though it's a latlong WGS84 projection
Markus Neteler
neteler at itc.it
Tue Feb 7 16:39:22 EST 2006
Maciek,
(cc Frank)
I had the same problem with v.in.ogr today (using GDAL/OGR from CVS).
Frank, did anything in GDAL/OGR recently change which makes fail the
recognition of the GRASS location projection in r.in.gdal/v.in.ogr?
This used to work.
Markus
On Tue, Feb 07, 2006 at 12:14:50PM +0100, guest user via RT wrote:
> Update - I've made a mistake usimg full file name N51E016.hgt.zip for input
> instead of N51E016 only. Now I used it correctly but still the error about
> projection is present:
> $ r.in.srtm input=/home/john/gis/dane/srtm2/N51E016 output=N51E016
> Extracting /home/john/gis/dane/srtm2/N51E016...
> Archive: /home/john/gis/dane/srtm2/N51E016.hgt.zip
> inflating: N51E016.hgt
> Converting input file to BIL...
> GRASS_INFO_ERROR(15045,1): Projection of dataset does not appear to match
> current location.
> LOCATION PROJ_INFO is:
> GRASS_INFO_ERROR(15045,1): name: Latitude-Longitude
> GRASS_INFO_ERROR(15045,1): datum: wgs84
> GRASS_INFO_ERROR(15045,1): towgs84: 0.000,0.000,0.000
> GRASS_INFO_ERROR(15045,1): proj: ll
> GRASS_INFO_ERROR(15045,1): ellps: wgs84
> cellhd.proj = 0 (unreferenced/unknown)
> You can use the -o flag to r.in.gdal to override this check and use the
> location definition for the dataset.
> GRASS_INFO_ERROR(15045,1): Consider generating a new location from the input
> dataset using the 'location' parameter.
> ERROR: N51E016 - map not found
> Done: generated map N51E016
> (Note: Holes in the data can be closed with 'r.fillnulls' using splines)
> Maciek
> -------------------------------------------- Managed by Request Tracker
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
