[GRASS5] g|r.region
Brad Douglas
rez at touchofmadness.com
Tue Feb 7 18:22:14 EST 2006
On Tue, 2006-02-07 at 22:36 +0100, Markus Neteler wrote:
> On Tue, Feb 07, 2006 at 09:28:33PM +0000, Glynn Clements wrote:
> > Brad Douglas wrote:
> > > Is there a specific reason to keep r.region around? Is there a case
> > > where you want to have a specific raster in a different metric than the
> > > global?
> > r.region exists for a specific purpose: to "fix" the region
> > information for rasters which were imported without georeferencing
> > information.
> > > If so, why is there no v.region?
> > Ungeoreferenced vector maps are uncommon,
> Most CAD drawings are not georeferenced - so in this
> "niche" it's very common (unfortunately).
Unless there are no reference data/points (or in XY "projection"), I
tend to manipulate my data with GDAL before importing into GRASS. I'm
not a heavy end-user, though.
> > and there is already v.transform.
Would it make sense to move this functionality to g.region to keep all
region related work in a single module? A flag '-s' could be added in
order to set the region of a particular map (be it vector or raster).
I can see strong cases made for both modular and unified functionality.
Brad Douglas <rez at touchofmadness.com> KB8UYR
Address: 37.49,-121.92 / WGS84 National Map Corps #TNMC-3785
GRASS GIS Developer
