[GRASSLIST:10222] Re: [GRASS5] r.to.rast3 and r.info
Sören Gebbert soerengebbert at gmx.de
Thu Feb 9 08:57:44 EST 2006
On Thursday 09 February 2006 14:39, Markus Neteler wrote:
> Sören Gebbert wrote:
> >Dear list,
> >FYI a new raster module is available in cvs now (many thanks to Markus) called:
> >r.to.rast3
> >This new/old module, formerly known as r3.in.rast,
> >converts 2D raster map slices into one G3D raster map.
> >I have renamed it, because there was a discussion about the name some months ago.
> So I should remove it from CVS then, right?
That would be nice, thank you.
> >r.info has now a new flag "-p", to add the timestamp information of a raster map to the r.info report. (also in cvs now)
> Let me suggest a modification to this flag: it should only print the
> time stamp (for identical
> behaviour of the r.info flags). The full description (no flags) should
> now always contain the
> time stamp, but maybe "undefined" in case of undefined (and not 0  00 0 ).
You are right, i will implement this behaivor in r.info and r3.info.
Greets
Soeren
> Markus
