[GRASS5] r.to.rast3 and r.info
Markus Neteler neteler at itc.it
Thu Feb 9 09:09:02 EST 2006
[sorry, I intended to post to the grass-dev list]
On Thu, Feb 09, 2006 at 02:57:44PM +0100, Sören Gebbert wrote:
> > >Dear list,
> > >FYI a new raster module is available in cvs now (many thanks to Markus) called:
> > >r.to.rast3
> > >This new/old module, formerly known as r3.in.rast,
> > >converts 2D raster map slices into one G3D raster map.
> > >I have renamed it, because there was a discussion about the name some months ago.
> > So I should remove it from CVS then, right?
> That would be nice, thank you.
done. I have also updated d.m and gis.m.
> > >r.info has now a new flag "-p", to add the timestamp information of a raster map to the r.info report. (also in cvs now)
> > Let me suggest a modification to this flag: it should only print the
> > time stamp (for identical
> > behaviour of the r.info flags). The full description (no flags) should
> > now always contain the
> > time stamp, but maybe "undefined" in case of undefined (and not 0  00 0 ).
> You are right, i will implement this behaivor in r.info and r3.info.
Thanks
 Markus
