[GRASS5] [bug #4074] (grass) Grass does not built libgrass_interpfl
Markus Neteler neteler at itc.it
Thu Feb 9 10:44:51 EST 2006
On Thu, Feb 09, 2006 at 04:39:22PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4074
> Subject: Grass does not built libgrass_interpfl
> Platform: Mac OSX
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 20060204
> Grass 6.1.cvs 20060204 does not built libgrass_interpfl. This worked in Grass 6.1.cvs 20060121.
> I have an error in multiple definitions of symbol.
> ld: warning multiple definitions of symbol _locale_charset
> /usr/local/grasslib/lib/libintl.dylib(localcharset.o) definition of _locale_charset
> /usr/lib/libiconv.2.dylib(localcharset.o) definition of _locale_charset
> ld: Undefined symbols:
> _G_site_new_struct
> /usr/bin/libtool: internal link edit command failed
> make[3]: *** [/src/grass-6.1.cvs_src_snapshot_2006_02_04/dist.powerpc-apple-darwin7.9.0/lib/
> libgrass_interpfl.6.1.cvs.dylib] Error 1
> Platform: Mac OS X
Lorenzo,
some functions were moved from libgis to libsites.
Can you add
$(SITESLIB) to the EXTRA_LIBS line in
lib/rst/interp_float/Makefile
after $(VECTLIB)
? this should cure the problem.
I have updated it in CVS.
Markus
