[GRASS5] Re: GRASS testsuite issue
Maris Nartiss
maris.gis at gmail.com
Sat Feb 11 06:21:42 EST 2006
IMHO relaying on md5 on different machines and systems is bad idea.
Will it work on MacOS, win32? I mean - will always GRASS output be
same eaven if it looks same from GRASS app view?
just thinking...
Maris.
2006/2/10, Sören Gebbert <soerengebbert at gmx.de>:
> Dear list,
> while developing the new GRASS testsuite, i noticed some unexpected
> behavior.
> I try to validate the generated output of grass modules with md5 checksum
> tests.
> I check the binary files in the grass location (cell, fcell, topo, coor and
> other files ).
> I was expecting the output of grass (raster, raster3d and vector) is equal
> on x86 machines,
> but after some testing i recognized that the output differs.
> If i create raster map's with r.mapcalc or r3.mapcalc and use sin() and
> cos(), the md5
> checksums are differ between Linux AMD gcc-3.4.4 and Linux P4 gcc-4.0.3
> systems.
> The same with v.buffer. But the command "r.mapcalc test=10" produce's equal
> output.
> How could this happen? Have the compiler, libraries (math?) or other
> software influence of the
> data generation, or is this a feature of the gislib?
> Maybe the optimize funciton of gcc (-On, SSE, mmx, 3dnow and stuff) produce
> this behavior?
> I dont know, but i need help. If there is no way no avoid this behavior,
> the md5 checksum test (an important feature) will not work :( .
> A work-around may be: to check the output exported with the *.out.ascii
> modules?
> What to do? Any help or suggestions?
> Best regards
> Soeren
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
