[GRASS5] Problem compiling with gdal and/or fftw
Michael Rensing michael.rensing at shaw.ca
Mon Feb 13 21:19:37 EST 2006
Thanks everyone. I buess I was fooled into thinking that fftw3 would
replace fftw2 in all cases when yum update automagically replaced it.
I'll see if I can re-install fftw2.
Has anyone got a quick explanation why the two versions of fftw are not
compatible?
Also, thanks for the link on GRASS and GDAL. I'm still having trouble
finding all the information resources on GRASS, so every bit helps.
Michael
Markus Neteler wrote:
>On Mon, Feb 13, 2006 at 03:39:37PM +0000, Glynn Clements wrote:
>>Michael Rensing wrote:
>>You need to configure GRASS using --without-fftw if you don't have
>>FFTW 2.x.
>>If your GDAL library was built with GRASS support, and you no longer
>>have a working version of GRASS, you will need to first build GDAl
>>without GRASS support before you can build GRASS. If you wish, you can
>>re-build GDAL with GRASS support once you have built GRASS.
>Michael,
>this is explained in detail here:
> http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
>Markus
>_______________________________________________
>grass5 mailing list
>grass5 at grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
