[GRASS5] Problem compiling with gdal and/or fftw
Markus Neteler neteler at itc.it
Mon Feb 13 10:56:37 EST 2006
On Mon, Feb 13, 2006 at 03:39:37PM +0000, Glynn Clements wrote:
> Michael Rensing wrote:
> You need to configure GRASS using --without-fftw if you don't have
> FFTW 2.x.
> If your GDAL library was built with GRASS support, and you no longer
> have a working version of GRASS, you will need to first build GDAl
> without GRASS support before you can build GRASS. If you wish, you can
> re-build GDAL with GRASS support once you have built GRASS.
Michael,
this is explained in detail here:
 http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassQgisGdalOgrPlugin
Markus
