[GRASSLIST:10291] Re: [GRASS5] New release candidate 3 of GIS
Manager 2
Glynn Clements
glynn at gclements.plus.com
Tue Feb 14 04:46:54 EST 2006
Michael Barton wrote:
> In most graphic programs (perhaps CAD excepted), if you select a line tool,
> it is only selected until you have completed the line. It does not stay
> selected to allow you to keep drawing lines. Again, this is commonly
> expected behavior because it is the way that may graphic programs work.
That isn't my experience. I find it more common for "tools" to remain
active until you explicitly select a different tool.
