[GRASSLIST:10291] Re: [GRASS5] New release candidate 3 of GIS Manager 2
Daniel Calvelo dca.gis at gmail.com
Tue Feb 14 10:38:06 EST 2006
Why not follow Corel Draw's convention of having:
- a zoom+ tool
- a zoom- tool (this one I find quite useless, personally)
- a zoom-once "tool", which reverts to the previously used tool after
rubberbanding
Daniel.
On 2/14/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
> > In most graphic programs (perhaps CAD excepted), if you select a line tool,
> > it is only selected until you have completed the line. It does not stay
> > selected to allow you to keep drawing lines. Again, this is commonly
> > expected behavior because it is the way that may graphic programs work.
> That isn't my experience. I find it more common for "tools" to remain
> active until you explicitly select a different tool.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
-- Daniel Calvelo Aros
