[GRASS5] r.composit?
Kirk R. Wythers
kwythers at umn.edu
Tue Feb 21 14:38:04 EST 2006
On Feb 21, 2006, at 9:33 AM, Kirk R. Wythers wrote:
> Is r.composit working for folks who are running a recent cvs version?
> I am trying to use it on three not terribly large or unusual files
> and it seems to get stuck on the second color (I killed the process
> after 20 minutes or so). Am I being impatient? I don't remember
> that r.composit was a long or slow process (at least with the
> default levels=32 setting).
> GRASS 6.1.cvs (minnesota_utm):~/projects/wrf/ts2325Exports >
> r.composite red=t61nr9w_1.red green=t61nr9w_1.green
> blue=t61nr9w_1.blue output=t61nr9w_1
> 100%
> ^C 0%
While I'm not sure why, the solution to this problem seems to be that
the region settings were not correct. I re-set the region, and
r.composite worked fine. Sorry for the confusion.
> Thanks,
> Kirk
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
