[GRASSLIST:10435] Re: [GRASS5] gis manager 2 rc3 - bug fixes and
updates
Glynn Clements
glynn at gclements.plus.com
Wed Feb 22 08:11:02 EST 2006
Michael Barton wrote:
> IMPORTANT NOTE. There has been a recent change in the way the monitorcap
> file is created that is causing problems in starting any command that
> requires an xmon display from the GIS Manager. I think it is an error in the
> makefile for XDRIVER, but I haven't messed with this.
> Monitorcap is being created with a double set of xmon definitions.
> Currently, you will need to edit this file to delete the second set of
> definitions for xmon (x0-x6). Hopefully, this can be corrected.
I cannot reproduce this. If you are getting a second set which doesn't
include x7, you have some out-of-date files in your build tree. Try
"make distclean" and "cvs update".
