[GRASS5] Segfault of v.in.ogr with OGR-layer
    Stephan Holl
    holl at gdf-hannover.de
    Wed Feb 22 11:00:36 EST 2006
Dear List,
I am trying to import an ogr-Datasource into GRASS using v.in.ogr.
The following error appears:
(gdb) r dsn=OCI:user/pw at oracle.galileo out=a layer=SPEAR_SOILS
Starting
program: /home/holl/cvs/grass_HEAD/dist.i686-pc-linux-gnu/bin/v.in.ogr
dsn=OCI:user/pw at oracle.galileo out=a layer=SPEAR_SOILS [Thread
debugging using libthread_db enabled] [New Thread -1234180384 (LWP
21724)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1234180384 (LWP 21724)]
0xb79031b0 in strcmp () from /lib/tls/libc.so.6
(gdb) bt
#0  0xb79031b0 in strcmp () from /lib/tls/libc.so.6
#1  0xb7a254f2 in G_find_key_value (key=0x0, kv=0x817d1b0) at
key_value1.c:107 #2  0xb7a25907 in G_lookup_key_value_from_file
(file=0x0, key=0x0, value=0xbfdc1600 "", n=80) at key_value4.c:49 #3
0xb7aefdf1 in GPJ_osr_to_grass (cellhd=0xbfdc1650, projinfo=0xbfdc27c8,
projunits=0xbfdc27cc, hSRS=0x81517b0, interactive=0) at convert.c:352
#4  0x0804d4e8 in main (argc=0, argv=0xbfdc5da4) at main.c:384
I received this on a fresh CVS-HEAD-Checkout of today.
When I do this with the ogr2ogr-tool I can access the datasource fine,
everything works. But GRASS does not :-(
Perhaps anybody could give me some pointers where I should dig deeper?
A bt full backtrace from gdb is provided here[1] (longish).
Thanks in advance
	Stephan
[1] http://www.gdf-hannover.de/holl/tmp/grass_bt_full_2006-02-22.txt
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
