[GRASS5] [bug #4111] (grass) d.m crashes
Michael Barton
michael.barton at asu.edu
Wed Feb 22 19:14:04 EST 2006
I've done this now. So hopefully it is finally solved. Thanks for the
advice.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Wed, 22 Feb 2006 17:54:39 +0000
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: <grass5 at grass.itc.it>, Michael Barton <michael.barton at asu.edu>
> Subject: Re: [GRASS5] [bug #4111] (grass) d.m crashes
> Request Tracker wrote:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4111
>> Subject: d.m crashes
>> Platform: Mac OSX
>> grass binary for platform: Compiled from Sources
>> GRASS Version: 6.1.cvs checked out 02222006
>> Kirk Wythers. I noticed that d.m crashes now upon startup. The error message
>> is:
>> GRASS 6.1.cvs (minnesota_utm):~ > d.m
>> GRASS 6.1.cvs (minnesota_utm):~ > Error in startup script: child process
>> exited abnormally
>> while executing
>> "close $input"
>> (procedure "Dm::create" line 38)
>> invoked from within
>> "Dm::create"
>> (procedure "main" line 33)
>> invoked from within
>> "main $argc $argv"
>> (file "/usr/local/grass-6.1.cvs/etc/dm/d.m.tcl" line 1629)
> The "close $input" should be within the catch, as $input won't be
> valid if the open command fails.
> While glancing at the code, I also noticed the following in both
> Dm::displmon and Dm::monitor:
> return
> close $input
> The close needs to come before the return.
