[GRASS5] d.m and d.mon fail after cvs update
    Michael Barton
    michael.barton at asu.edu
    Thu Feb 23 00:50:02 EST 2006
I had this problem, but fixed it in a different way and so need to ask about
it.
I had a strange monitorcap (with double xmon definitions) file that came
with the most recent (13 February) Mac binary from Lorenzo Moretti. Perhaps
this is/was being generated during Mac compiles as this seems to be reported
by Mac folks.
When I fixed the monitorcap file AND commented out the following line...
                #set env(MONITOR_OVERRIDE) "gism"
in the procedure that creates the output PPM and then creates a TclTk image
from thePPM, it worked.
With the fix you mention below, should I try uncommenting the
MONITOR_OVERRIDE statement?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Wed, 22 Feb 2006 17:56:41 +0000
> To: "Kirk R. Wythers" <kwythers at umn.edu>
> Cc: devel grass <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] d.m and d.mon fail after cvs update
> Kirk R. Wythers wrote:
>> and d.mon x0 fails with:
>> GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
>> Problem selecting x0. Will try once more
>> Any thoughts?
> Known problem, mentioned in:
> Subject: [GRASS5] version.h.in broken
> Date: Tue, 21 Feb 2006 23:17:41 +0000
> Message-ID: <17403.40853.814866.311695 at cerise.gclements.plus.com>
> I've committed a fix (revert version.h.in to the previous version) to
> CVS.
