[GRASS5] d.m and d.mon fail after cvs update
Glynn Clements
glynn at gclements.plus.com
Thu Feb 23 09:59:19 EST 2006
Michael Barton wrote:
> I had this problem, but fixed it in a different way and so need to ask about
> it.
> I had a strange monitorcap (with double xmon definitions) file that came
> with the most recent (13 February) Mac binary from Lorenzo Moretti. Perhaps
> this is/was being generated during Mac compiles as this seems to be reported
> by Mac folks.
> When I fixed the monitorcap file AND commented out the following line...
> #set env(MONITOR_OVERRIDE) "gism"
> in the procedure that creates the output PPM and then creates a TclTk image
> from thePPM, it worked.
> With the fix you mention below, should I try uncommenting the
> MONITOR_OVERRIDE statement?
The use of MONITOR_OVERRIDE and the fix which I mentioned are
unrelated.
Without the version.h.in fix, monitor drivers will simply segfault at
startup. the fix is necessary to be able to use monitors.
MONITOR_OVERRIDE allows applications to redirect d.* commands to a
specific monitor without using "d.mon select=..." (which will
interfere with the user's use of monitors).
gis.m should always be using MONITOR_OVERRIDE rather than
"d.mon select=gism".
BTW, It is now be possible for gis.m (and similar programs, e.g.
d.out.png) to avoid the use of monitorcap altogether. You can start
monitors directly with e.g. (shell syntax):
$GISBASE/driver/PNG foo '' ''
MONITOR_OVERRIDE=foo d.vect fields
d.mon stop=foo
# or:
# $GISBASE/etc/mon.stop foo
without the monitor name having to appear in the monitorcap file.
This doesn't work when using FIFOs, although I don't know if anyone
still uses FIFOs, and I'm inclined to remove FIFO support altogether
unless someone can provide a good reason why it needs to stay.
