[GRASS5] [bug #4118] (grass) can not use d.erase -f
Glynn Clements
glynn at gclements.plus.com
Sun Feb 26 11:22:08 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4118
> Subject: can not use d.erase -f
> Platform: WindowsNT/2000/XP
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: GRASS 6.0.0 (2005)
> I can not use "d.erase -f" to remove the frames when clearing the
> display, after using "d.rast.leg" as what's said on the Reference
> Manual.
> Here is screen info:
> GRASS 6.0.0 (spearfish):~ > d.erase -f
> Sorry, <f> is not a valid flag
The -f flag isn't present in 6.0.0. It was added on 2005/06/21, so you
will need a version which was released after that date.
[BTW, neither 6.0.1 nor 6.0.2 appear to have CVS tags, so it's
impossible to determine which version of a file was used for those
releases.]
