[GRASS5] [bug #4118] (grass) can not use d.erase -f
Markus Neteler neteler at itc.it
Sun Feb 26 17:06:49 EST 2006
On Sun, Feb 26, 2006 at 04:22:08PM +0000, Glynn Clements wrote:
> Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4118
> > Subject: can not use d.erase -f
> > Platform: WindowsNT/2000/XP
> > grass binary for platform: Downloaded precompiled Binaries
> > GRASS Version: GRASS 6.0.0 (2005)
> > I can not use "d.erase -f" to remove the frames when clearing the
> > display, after using "d.rast.leg" as what's said on the Reference
> > Manual.
> > Here is screen info:
> > GRASS 6.0.0 (spearfish):~ > d.erase -f
> > Sorry, <f> is not a valid flag
> The -f flag isn't present in 6.0.0. It was added on 2005/06/21, so you
> will need a version which was released after that date.
> [BTW, neither 6.0.1 nor 6.0.2 appear to have CVS tags, so it's
> impossible to determine which version of a file was used for those
> releases.]
Good point. I'll tag 6.0.2 now and update the release procedure.
Markus
