[GRASS5] v.in.ogr PRJ issue
Kirk R. Wythers
kwythers at UMN.EDU
Mon Feb 27 11:05:00 EST 2006
I don't know the answer here Markus, but I have noticed this same
message on much of the work that I have been doing for the last few
weeks with grass and postgres. Since the imports from v.in.ogr -o can
be displayed properly, I have been ignoring the message.
Kirk
On Feb 27, 2006, at 9:50 AM, Markus Neteler wrote:
> Hi,
> I tried to import the sample soils map from
> PostGIS (1.1.x, on PG 8.0.x):
> ogrinfo "PG:host=localhost dbname=postgis" soils | head -25
> INFO: Open of `PG:host=localhost dbname=postgis'
> using driver `PostgreSQL' successful.
> Layer name: soils
> Geometry: Polygon
> Feature Count: 737
> Extent: (589443.750000, 4913923.000000) - (609546.187500,
> 4928106.000000)
> Layer SRS WKT:
> PROJCS["UTM Zone 13, Northern Hemisphere",
> GEOGCS["clark66",
> DATUM["North_American_Datum_1927",
> SPHEROID["clark66",6378206.4,294.9786982]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-105],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["meter",1]]
> FID Column = ogc_fid
> Geometry Column = wkb_geometry
> cat: Integer (0.0)
> label: String (0.0)
> But GRASS tells me:
> v.in.ogr dsn="PG:host=localhost dbname=postgis" layer=soils
> output=soils_pg type=boundary,centroid
> ERROR: Projection of dataset does not appear to match current
> location.
> LOCATION PROJ_INFO is:
> datum: nad27
> nadgrids: conus
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
> cellhd.proj = 0 (unreferenced/unknown)
> You can use the -o flag to v.in.ogr to override this check.
> Consider to generate a new location with 'location'
> parameter from
> input data set.
> It seems that there are still definition issues with PROJ.
> any ideas?
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
