[GRASS5] v.in.ogr PRJ issue
Stephan Holl
holl at gdf-hannover.de
Tue Feb 28 02:41:48 EST 2006
Hello Markus,
On Mon, 27 Feb 2006 16:50:05 +0100 Markus Neteler <neteler at itc.it>
wrote:
> Hi,
> I tried to import the sample soils map from
> PostGIS (1.1.x, on PG 8.0.x):
> ogrinfo "PG:host=localhost dbname=postgis" soils | head -25
> INFO: Open of `PG:host=localhost dbname=postgis'
> using driver `PostgreSQL' successful.
> Layer name: soils
> Geometry: Polygon
> Feature Count: 737
> Extent: (589443.750000, 4913923.000000) - (609546.187500,
> 4928106.000000) Layer SRS WKT:
> PROJCS["UTM Zone 13, Northern Hemisphere",
> GEOGCS["clark66",
> DATUM["North_American_Datum_1927",
> SPHEROID["clark66",6378206.4,294.9786982]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-105],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["meter",1]]
> FID Column = ogc_fid
> Geometry Column = wkb_geometry
> cat: Integer (0.0)
> label: String (0.0)
> But GRASS tells me:
> v.in.ogr dsn="PG:host=localhost dbname=postgis" layer=soils
> output=soils_pg type=boundary,centroid ERROR: Projection of dataset
> does not appear to match current location.
> LOCATION PROJ_INFO is:
> datum: nad27
> nadgrids: conus
> proj: utm
> ellps: clark66
> a: 6378206.4000000004
> es: 0.0067686580
> f: 294.9786982000
> zone: 13
> cellhd.proj = 0 (unreferenced/unknown)
> You can use the -o flag to v.in.ogr to override this check.
> Consider to generate a new location with 'location' parameter
> from input data set.
> It seems that there are still definition issues with PROJ.
> any ideas?
I have found the opposite behaviour. I can import any dataset with
different proj-information inside the spearfish60-location...
Something is messed up there.
Could anybody have a look into this?
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
