[GRASS5] Automated test-system for basic functionalities.
Roger Bivand
Roger.Bivand at nhh.no
Tue Jan 10 10:31:20 EST 2006
On Tue, 10 Jan 2006, Radim Blazek wrote:
> On 1/10/06, Sören Gebbert <soerengebbert at gmx.de> wrote:
> > But if the test description is a shell script the user/dev will have more options to write tests.
> Do we need such options?
> > We can define the test description in xml and write the framework in C/C++,
> > but in this case im not able write the framework (i dont have the time and the knowledge). :(
> No! I prefer something very simple. To use checksum is good idea.
> My idea was to have test location with some input maps in PERMANENT.
> Then the test descriptions could be a text file with GRASS commands
> and list of output data to be verified + checkums for that data.
Yes, better described than by me, this will work, I'm pretty sure. Simple
and robust.
Roger
> Radim
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
