[GRASS-dev] Re: [bug #4768] (grass) nviz segfault on startup when
William Kyngesburye
woklist at kyngchaos.com
Mon Jul 3 13:37:36 EDT 2006
I've tried a couple things, and I can think of 2 possibilities:
- since togl demos work, possibly there is something wrong with the
window NVIZ is trying to setup. I tried removing the togl
glXQueryExtension test to force it to assume that glX is OK - it got
further, but failed later when X11 wanted to test that on its own:
0 libX11.6.dylib 0x9b4bdfa1 XQueryExtension + 24
1 libX11.6.dylib 0x9b4b4fb1 XInitExtension + 47
2 libXext.6.dylib 0x9b49aec9 XextAddDisplay + 64
3 libGL.1.dylib 0x9b5b9c2a __glXFindDisplay + 116
4 libGL.1.dylib 0x9b5ba304 __glXInitialize + 25
5 libGL.1.dylib 0x9b5b6b23 GetGLXPrivScreenConfig
+ 27
6 libGL.1.dylib 0x9b5b78a9 glXChooseVisual + 38
7 nviz 0x00011a31 Togl_CreateWindow + 1070
I also tried linking in my test installed togl, instead of using the
included togl in the nviz source - same errors.
- There is something wrong with glX in Apple's X11 that only shows up
(so far) with NVIZ. I need to find some OpenGL demos that use glX,
next.
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
