[GRASS-dev] [bug #4310] (grass) db.drivers: what do the -pf
actually do?
Maciek Sieczka via RT
grass-bugs at intevation.de
Mon Jul 10 05:09:07 EDT 2006
Hamish wrote:
> The module is to tell you about installed db DRIVERS not TABLES.
> It is working fine.
Hamish,
Yes it is *partially* working fine *now*, *after* Markus fix. Before it used
to refer to tables (in error) and that's one point of the bug report.
The other thing is that -f "Full output" still prints only:
$ db.drivers -f
sqlite:
dbf:
ogr:
pg:
For which you seem to have found the reason:
> AFAICT, comment is unused in GRASS 6 (???).
> see lib/db/dbmi_base/dbmscap.c
(code details in the BT)
Could that be fixed?
Cheers,
Maciek
-------------------------------------------- Managed by Request Tracker
