[GRASS-dev] GRASS 6.1.0 branch status
Michael Barton michael.barton at asu.edu
Sun Jul 23 13:37:33 EDT 2006
A big showstopper is also NVIZ being broken on Macs. Until William
Kyngesburye's report of today, the cvs version was broken on all Macs under
all TclTk versions.
I don't know what changed, but William reports that it is now working under
x11 on all Macs. So this is a huge improvement. I'll try to confirm this
next week. If he can get it working under aqua, we'll be set.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Bob Covill <bcovill at tekmap.ns.ca>
> Date: Sat, 22 Jul 2006 12:23:55 -0300
> To: Markus Neteler <neteler at itc.it>
> Cc: GRASS developers list <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] GRASS 6.1.0 branch status
> Markus,
> On Sat, 2006-07-22 at 13:25 +0200, Markus Neteler wrote:
>> On Sat, Jul 22, 2006 at 12:37:53PM +0200, Markus Neteler wrote:
>>> Next week we should get out 6.1.0beta2 or maybe RC1.
>> We still have the following open issues:
>> Showstoppers:
>> * NVIZ volume broken (IMHO showstopper, since this worked already)
>>    https://intevation.de/rt/webrt?serial_num=4725
>> * wording of start up GUI text (showstopper)
>> Not showstoppers:
>> * NVIZ: show vector map on startup (Bob? Your patch doesn't work for me)
> The two potential problems with the patch are the vertical exaggeration,
> and the initial line color. If the vertical exaggeration is too high the
> vector may be out out view. If you lower the vertical exaggeration does
> the vector come into view? If the initial line color (set in map_obj.c)
> is white and the background is white the vector will be invisible. Try
> changing the color of the vector after start-up to see if the vector
> appears.
> In the meantime I will keep looking into this.
>> * debian/ directory outdated (who cares)
>> * i.vpoints status?
>> * v.in.gpsbabel - db.login error (who cares?)
>>    http://grass.itc.it/pipermail/grass-dev/2006-July/024188.html
>> * test latest gis.m fixes
>> * G_make_aspect*_colors() broken
>>    http://grass.itc.it/pipermail/grass-dev/2006-July/024228.html
>> * sqlite driver memory consumption
>>    http://grass.itc.it/pipermail/grass-dev/2006-July/024232.html
>> * v.digit: $mapname in the title bar
>>    http://intevation.de/rt/webrt?serial_num=4796
>> Further discussion (old business):
>> * The x11-less GRASS can be developed in HEAD, we should
>>   not wait for that. We can have 6.1.1 if desired in near
>>   future. The same applies to the georectifier.
>> * NVIZ/Mac issues we can port from HEAD once they get fixed.
>> * snprintf(): now G_snprintf()
>> * An announcement is drafted at
>>   http://grass.itc.it/announces/announce_grass610.html
>> Markus
>> grass-dev mailing list
>> http://grass.itc.it/mailman/listinfo/grass-dev
> Bob
