[GRASS-dev] [bug #4899] (grass) v.in.ogr in tcltk: open datasource
dialog does not allow to select directoy
Request Tracker
grass-bugs at intevation.de
Mon Jul 24 12:18:33 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4899
Subject: v.in.ogr in tcltk: open datasource dialog does not allow to select directoy
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060724
I know this has been mentioned before (quite a while ago), but it is still annoying: when using v.in.ogr in its tcltk dialog you cannot chose a directory as a data source, e.g. when importing a shapefile.
I know I can just select the file and then erase the file name from the path, but if this could be easily solved that would be great.
Moritz
-------------------------------------------- Managed by Request Tracker
