[GRASS-dev] [bug #2794] (grass) wish window mouse wheel and TAB
Maciek Sieczka via RT
grass-bugs at intevation.de
Thu Jun 22 15:14:15 EDT 2006
Is done for gis.m.
In d.m wheel doesn't work (CVS 2006.06.19), although about a month ago it used
to output an error if tried (http://intevation.de/rt/webrt?serial_num=4466).
Was it an unseccussfell, then reverted, attempt to support wheel in d.m? Any
chances wheel will work in d.m?
File selection dialogs support wheel nicely.
"Options" panel in modules is quite OK, besides modules like v.to.db, where
scrolling parameters' selection lists (e.g. v.to.db's "Value to upload", i.e.
"option=" parameter) causes the whole panel to be scrolled, instead of the
parameters list alone.
"Output" panel is mostly scrollable, besides when mouse pointer hovers over
the grey belt with icons and command syntax - no scrolling then. If there is
not much space between subsequent grey belts, the panel is hardly scrollable
at all.
The TAB key circulates through the "Options" panel OK, only it shouldn't
bother stopping at the top icon (strange, why is it pressable?) next to module
description and at the bottom icon (the copy-command one).
Nice progress but still stuff missing. What are the plans?
Maciek
-------------------------------------------- Managed by Request Tracker
