[GRASS-dev] i.points, i.vpoints now use G_parser()
Mon Jun 26 07:19:03 EDT 2006
Hamish wrote:
> > > What information does it return and in what format?
> > Number of active points: %d
> > Forward:
> > x[%d] = %.2f
> > y[%d] = %.2f
> > g[%d] = %.2f
> > RMS = %.2f
> %.2f isn't very useful if you are registering a scan of a lat/lon map
> (eg nautical chart). This has always been a pain in i.[v]points, you
> only judge to include/exclude a point based on what lines are colored
> red.
> maybe a check?
>   if(G_projection() == PROJECTION_LL)
>      %.5f
> or G_trim_decimal() ??
Seems reasonable enough.
What would be an appropriate precision for the reverse error (i.e.
distances in X-Y coordinates)?
