[GRASS5] New gui.tcl
Glynn Clements
glynn at gclements.plus.com
Sun Mar 19 15:06:50 EST 2006
Hamish wrote:
> > There is a new command label which shows the current command as it is
> > edited. It has a button for copying the command to the clipboard.
> > (Might be worth noting in wish 2074)
> Nice to have this back (clearly). It is something I missed from the
> GRASS 5 GUI. Problem: I can see it in xclipboard, and ^V pastes it in
> nedit, but middle-click to paste in doesn't work?
Ctrl-V (or Shift-Insert) usually pastes the clipboard, while the
middle mouse button usually pastes the primary selection.
For xterm, you can change the behaviour with e.g.
*vt100.translations: #override \n\
~Ctrl ~Meta <Btn2Up>: insert-selection(CLIPBOARD, PRIMARY, CUT_BUFFER0)
This will cause it to prefer the clipboard over the primary selection.
Tk supports setting the primary selection, but it's a bit more work
than using the clipboard (and, nowadays, probably less useful).
