[GRASS5] [bug #4214] (grass) r.info: new timestamp effort is
ambiguous
Glynn Clements
glynn at gclements.plus.com
Tue Mar 28 15:00:27 EST 2006
Hamish wrote:
> > If you want localisation, do it when you display the timestamp to the
> > user (i.e. in r.info).
> G__write_timestamp() would still use G_format_timestamp(); I was
> suggesting G_format_timestamp_l10n() to be used by modules like r.info.
Right. There are two options for that:
1. Use strftime's "%c" specifier:
%c The preferred date and time representation for the current
locale.
2. Provide a user option (e.g. an environment variable) which
specifies an strftime() format string, falling back to #1 if the
variable (etc) is unset.
