[GRASS-dev] Re: [GRASS-user] Build Grass62!
    Hamish
    hamish_nospam at yahoo.com
    Mon Nov 20 18:22:01 EST 2006
Hamish:
> > "mkdir -p" isn't quoting the path
Glynn:
> That looks like a bug in the Makefile(s); can you say which one(s)?
grass63$ grep -rI "mkdir -p" *
ChangeLog:      * lib/vector/dglib/Makefile: mkdir -p
ChangeLog.bak:  * lib/vector/dglib/Makefile: mkdir -p
Makefile:MAKE_DIR_CMD=          mkdir -p -m 755
Makefile:       @test -d $(GRASS_PDFDIR) || mkdir -p $(GRASS_PDFDIR)
binaryInstall.src:    mkdir -p $BINDIR
binaryInstall.src:    mkdir -p $DESTDIR
debian/rules:   #mkdir -p debian/tmp/usr/share/grass/bwidget
gem/reg_entries.c:              sprintf ( str, "mkdir -p %s/etc/gm/Xtns ; cp -f ../entries-gisman2 %s/etc/gm/Xtns/%s.gem ; ",
include/Make/Grass.make.in:     mkdir -p $(ARCH_BINDIR)
include/Make/Grass.make.in:     mkdir -p $(ARCH_INCDIR)
include/Make/Grass.make.in:     mkdir -p $(ARCH_LIBDIR)
include/Make/Grass.make.in:     mkdir -p $(BIN)
include/Make/Grass.make.in:     mkdir -p $(ETC)
include/Make/Grass.make.in:     mkdir -p $(DRIVERDIR)
include/Make/Grass.make.in:     mkdir -p $(DBDRIVERDIR)
include/Make/Grass.make.in:     mkdir -p $(FONTDIR)
include/Make/Platform.make.in:MKDIR               = mkdir -p
include/Make/Grass.make:        mkdir -p $(ARCH_BINDIR)
include/Make/Grass.make:        mkdir -p $(ARCH_INCDIR)
include/Make/Grass.make:        mkdir -p $(ARCH_LIBDIR)
include/Make/Grass.make:        mkdir -p $(BIN)
include/Make/Grass.make:        mkdir -p $(ETC)
include/Make/Grass.make:        mkdir -p $(DRIVERDIR)
include/Make/Grass.make:        mkdir -p $(DBDRIVERDIR)
include/Make/Grass.make:        mkdir -p $(FONTDIR)
include/Make/Platform.make:MKDIR               = mkdir -p
lib/init/make_location_epsg.sh.in:mkdir -p $GISDBASE/$TEMPDIR/PERMANENT
rpm/fedora/grass_FC4.spec: mkdir -p %{buildroot}%{_libdir}/pkgconfig
rpm/fedora/gdal-ogr-grass-plugin.spec:mkdir -p ${AUTOLOAD}
scripts/r.in.wms/wms.request:  mkdir -p "${GIS_OPT_FOLDER}"
scripts/v.db.addtable/v.db.addtable:        mkdir -p ${GISDBASE}/${LOCATION_NAME}/${MAPSET}/dbf
tools/build_html_index.sh:mkdir -p $HTMLDIR/gem
Hamish
