[GRASS-dev] shell scripts: variable bash-isms removed
Markus Neteler
neteler at itc.it
Fri Nov 24 07:52:50 EST 2006
from IRC logs I picked this problem:
"/usr/local/grass-6.2.1cvs/scripts/d.vect.thematic: LC_NUMERIC=C: is not an identifier"
(the user works on Solaris).
I have now fixed in CVS all "export" bash-isms in the scripts/
subdirectory and changed from
export VAR=value
to
VAR=value
export VAR
which should solve the problem.
Backported to 6.2 as well.
Markus
