[GRASS-dev] [bug #5176] (grass) v.in.ogr: segfault when a full
path to dsn is missing
Maciej Sieczka
tutey at o2.pl
Tue Oct 3 08:23:06 EDT 2006
Markus Neteler wrote:
> Best is to use a debugger. See here how to do that with 'ddd':
> http://grass.gdf-hannover.de/wiki/GRASS_Debugging#Using_DDD_.28gdb_graphical_frontend.29
OK, done, but some different way:
$ ulimit -c 3000
$ grass63
$ v.in.ogr dsn=force_lrconnect_cl_onlycat139
output=force_lrconnect_cl_onlycat139_import
layer=force_lrconnect_cl_onlycat139
(segfault)
$ gdb v.in.ogr core
(gdb) bt
#0 0x00010101 in ?? ()
#1 0xb7cb5c2f in OGRSpatialReference::Release ()
from /usr/local/lib/libgdal.so.1
#2 0xb7cab4e7 in OGRGeometry::~OGRGeometry () from
#3 0xb7ca6810 in OGRCurve::~OGRCurve () from /usr/local/lib/libgdal.so.1
#4 0xb7ca6ad8 in OGRLineString::~OGRLineString ()
#5 0xb7caf6ff in OGRFeature::~OGRFeature () from
#6 0xb7caefa5 in OGR_F_Destroy () from /usr/local/lib/libgdal.so.1
#7 0x0804ccfc in main (argc=4, argv=0xbffcb044) at main.c:744
(gdb) q
Any good?
Maciek
