[GRASS-dev] [bug #5176] (grass) v.in.ogr: segfault when a full
path to dsn is missing
Brad Douglas
rez at touchofmadness.com
Wed Oct 4 23:35:35 EDT 2006
On Tue, 2006-10-03 at 13:37 +0200, Maciek Sieczka via RT wrote:
> hamish_nospam at yahoo.com wrote (Tue, Oct 3 2006 05:47:19):
> >> $ v.in.ogr dsn=shorter/
> > what if you leave off the trailing "/" in the dsn?
> It doesn't change anything. Still a segfault if
> "dsn=force_lrconnect_cl_onlycat139" and no segfault if "dsn=shorter". Looks
> like the string length is the key.
Should be fixed in CVS.
Brad Douglas <rez touchofmadness com> KB8UYR
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
