[GRASS-dev] Re: [GRASS-user] v.clean tool=prune - 'thresh' interpreted wrong?
Maciej Sieczka tutey at o2.pl
Wed Oct 4 05:53:59 EDT 2006
Moritz Lennert wrote:
>>> To echo Hamish' question: Do you need to remove vertices from lines
>>> without changing the form of the line, or do you want to generalize the
>>> form of the line (in the way that is shown here:
>>> http://mpa.itc.it/markus/como2006/img9.html ?
>> The latter. I want to remove all the vertices that are distant from the
>> line starting node not more than the give thresh. A line:
>> x--o1-o2-->----o3--x
>> "x" - node
>> "o" - vertex
>> ">" - line direction
>> "-" - 1 length unit
>> thresh=3 would remove o1, thresh=5 the o1 and o2 and so on
> This sounds like something still different, as you make it dependent on
> the starting node.
Still we don't know how the thresh works for pruning.
> I don't think that the prune tool was ever thought to work this way.
You don't know how it works. Then how do you know how it doesn't work :) ?
Getting back to my original post.
The line:
$ echo "L 4 1
	 10 10
	 20 10
	 30 10
	 40 10
	 1     1" | v.in.ascii -n out=line format=standard
Imagine it as:
x-o1-o2-x
"x" - node
"o" - vertex
"-" - 5 length units
$ v.clean input=line output=line_pruned type=line tool=prune thresh=0.04
removes o1,o2. Anything bigger does the same. Anything smaller doensn't
remove any.
Why? Should it be like that or not?
Maciek
