[GRASS-dev] Re: [GRASS-user] v.clean tool=prune - 'thresh' interpreted wrong?
Markus Neteler neteler at itc.it
Wed Oct 4 05:58:31 EDT 2006
On Wed, Oct 04, 2006 at 11:53:59AM +0200, Maciej Sieczka wrote:
> Moritz Lennert wrote:
> > I don't think that the prune tool was ever thought to work this way.
> You don't know how it works. Then how do you know how it doesn't work :) ?
I made numerous tests in the past and it rarely worked as expected.
It also fails completely in LatLong since threshold is literally
taking the degree coords to calculate distances while it should be
the geodetic distance (as -m flag in g.region does).
Markus
