[GRASS-dev] help with r.le.setup bug
Thu Oct 5 19:00:01 EDT 2006
Hamish wrote:
> can one of the C gurus have a look at this?
> http://thread.gmane.org/gmane.comp.gis.grass.devel/15495/focus=15598
> I think it's a simple type mismatch in variables getting passed to a
> function.
It is. ux/uy are arrays of ints but calc_unit_loc() expects arrays of
doubles.
Try the attached patch.
Index: raster/r.le/r.le.setup/sample.c
RCS file: /grassrepository/grass6/raster/r.le/r.le.setup/sample.c,v
retrieving revision 2.6
diff -u -r2.6 sample.c
--- raster/r.le/r.le.setup/sample.c	28 Sep 2006 07:37:04 -0000	2.6
+++ raster/r.le/r.le.setup/sample.c	5 Oct 2006 22:57:59 -0000
@@ -108,9 +108,10 @@
   int      i, j, dx, dy, w_w, w_l, u_w, u_l,
 	   method, l0, t0, randflag=0, unit_num, num=0, scales,
-	   h_d=1, v_d=1, *ux, *uy, itmp, thick, sites, *row_buf, fr, k,
+	   h_d=1, v_d=1, itmp, thick, sites, *row_buf, fr, k,
 	   count=0, maxsize=0, nx=0, ny=0, numx=0, numy=0,
 	   al=0, ar=0, at=0, ab=0, au_w=0, au_l=0;
+  double *ux, *uy;
   FILE     *fp ;
   double   dtmp, ratio, size, intv=0.0, start[2], cnt=0, radius=0.0;
   char     *sites_mapset;
@@ -547,13 +548,13 @@
 				   units */
 	if (method != 5) {
-	   ux = (int *)G_calloc(num+1, sizeof(int));
-           uy = (int *)G_calloc(num+1, sizeof(int));
+	   ux = G_calloc(num+1, sizeof(double));
+           uy = G_calloc(num+1, sizeof(double));
 	else {
-	   ux = (int *)G_calloc(250, sizeof(int));
-           uy = (int *)G_calloc(250, sizeof(int));
+	   ux = G_calloc(250, sizeof(double));
+           uy = G_calloc(250, sizeof(double));
 				/* calculate the upper left corner of sampling
@@ -615,7 +616,7 @@
         radius, (i+1));
      for(j = 0; j < num; j++)
-	fprintf(fp, "%10d%10d   left, top of unit[%d]\n", ux[j], uy[j], j+1);
+	fprintf(fp, "%10d%10d   left, top of unit[%d]\n", (int) ux[j], (int) uy[j], j+1);
      if (i < scales - 1 && G_yes("\n\n    Refresh the screen?   ", 1)) {
 	paint_map(n1, n2, n3);
