[GRASS-dev] VASKLIB in IMAGERYLIB?
Brad Douglas rez at touchofmadness.com
Fri Oct 6 12:56:33 EDT 2006
On Fri, 2006-10-06 at 14:25 +0200, Radim Blazek wrote:
> Hi,
> adding VASKLIB to IMAGERYLIB breaks compilation of some modules
> (r.in.gdal) on windows  or --without-curses. VASKLIB is not used by in modules
> which use IMAGERYLIB, IMO VASKLIB should only be used in modules Makefiles
> which realy use it.
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/Make/Grass.make.in.diff?r1=1.60&r2=1.61
We should be moving away from VASKLIB, too...  Unfortunately, some parts
of IMAGERYLIB still require VASKLIB functions, IIRC. :(
Brad Douglas <rez touchofmadness com>                      KB8UYR
Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
