[GRASS-dev] VASKLIB in IMAGERYLIB?
Radim Blazek
radim.blazek at gmail.com
Fri Oct 6 14:42:44 EDT 2006
On 10/6/06, Brad Douglas <rez at touchofmadness.com> wrote:
> On Fri, 2006-10-06 at 14:25 +0200, Radim Blazek wrote:
> > Hi,
> > adding VASKLIB to IMAGERYLIB breaks compilation of some modules
> > (r.in.gdal) on windows or --without-curses. VASKLIB is not used by in modules
> > which use IMAGERYLIB, IMO VASKLIB should only be used in modules Makefiles
> > which realy use it.
> > http://freegis.org/cgi-bin/viewcvs.cgi/grass6/include/Make/Grass.make.in.diff?r1=1.60&r2=1.61
> We should be moving away from VASKLIB, too... Unfortunately, some parts
> of IMAGERYLIB still require VASKLIB functions, IIRC. :(
The functions which require VASKLIB are compiled only if HAVE_CURSES_H.
Radim
> Brad Douglas <rez touchofmadness com> KB8UYR
> Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
