[GRASS-dev] VASKLIB in IMAGERYLIB?
Glynn Clements
glynn at gclements.plus.com
Fri Oct 6 17:05:23 EDT 2006
Radim Blazek wrote:
> adding VASKLIB to IMAGERYLIB breaks compilation of some modules
> (r.in.gdal) on windows or --without-curses. VASKLIB is not used by in modules
> which use IMAGERYLIB, IMO VASKLIB should only be used in modules Makefiles
> which realy use it.
That approach fails if IMAGERYLIB is a shared library.
The most robust solution would be to move the parts of IMAGERYLIB
which depend upon VASKLIB into a separate library.
